vcLayoutItem
Basic implementation of all layout items.
Children: vcAnnotation, vcCollisionDetector, vcDimension, vcFocusModeManagerData, vcLayoutPackFolder, vcLayoutPropertyList, ... (see more)
vcAnnotation
vcCollisionDetector
vcDimension
vcLayoutPackFolder
vcLayoutSchemaPropertyList
vcProcessControllerData
vcSweptVolume
vcViewAnimation
vcProgramContainer
Referenced by: vcWorld.LayoutItems, vcWorld.createLayoutItem(), vcWorld.findLayoutItem()
| IsPersistent | Boolean | RW | Gets or sets a Boolean determening if the layout item is saved with layout. |
| Name | String | RW | Gets or sets the name of item. |
| Properties | vcPropertyContainer | R | Gets the properties of this layout item |
| Type | vcLayoutItemType | R | Gets the layout item type of the layout item. |
| delete | None | None | Deletes this layout item |
| update | None | None | Updates the item in its layout. |
